Shughes717
Ok, so if I were to instead spend $2k-$3200, what would people recommend?
Thanks.
gtduck, if your budget is $1800 or $2k-$3200 and you know you can't afford anything more expensive, don't let people's opinions on this or any other site convince you to spend $4k on a mower. You will get many different opinions about what to buy and what to stay away from. Yes, mowers under $2k are going to be lower quality than the higher end mowers. Manufacturers cut corners to get the price down so people on a tight budget can afford a rider. That doesn't mean those mowers won't last long if properly maintained. There will be some repairs needed eventually for anything you purchase. Drive train and deck build (thickness and # of gauge wheels) is what I would focus on if I were in your shoes. Get the best combination you can find in your budget. Kawasaki engines have a great reputation. I have owned a mower with the kohler command engine and it held up fine as well. Look at every brand available to you in your area and compare the mowers. Make your decision based on what you liked the best.
