Craftsman LT4000 spitting/sputtering and backfiring after riding for 5mins
Testing the magneto
The magneto, like the ignition coil on an automobile, contains two windings:
A primary with a few turns of heavy wire.
A high voltage secondary with thousands of turns of super fine wire.
In an automobile, the battery supplies the primary current; in a magneto, the magnet on the flywheel
moving past the core at high speed acts as a generator and induces current in the primary.
As the magnets spin past the pole pieces of the magneto core, the points are closed and current builds up
in the low voltage winding (and flux builds up in the core). At or slightly before Top Dead Center
(TDC), the current (and flux) should be maximum and at this instant the points open. The flux then
collapses (and the condenser (capacitor) across the points acts as a snubber allowing the current to
bypass the open points and preventing arcing at the point contacts). This rapid decrease in flux results in
coupling of the stored energy to the turn high voltage winding and results in up to 10,000 V or more at
the spark plug.
(For EE types, this is somewhat similar in basic operation to the fly-back converter in a switch-mode
power supply except that the moving magnet supplies the input power instead of the rectified AC line
and the points act as the switch instead of a power transistor.)
The secondary will always be accessible for testing but the primary of an electronic ignition may be not
be due to the electronic components:
Secondary: 3 K ohms (maybe a little higher but not open). Much lower would indicate a shorted
winding.
Primary (if non-electronic and accessible): very low - guessing less than an ohm.
Wires can break due to corrosion or vibration. This would result in an open winding - infinite resistance.
Shorts can develop between adjacent windings or to the core. This may be detectable as reduced
resistance but without knowing exactly what it should be, there is no way of knowing if a slight
discrepancy represents a problem or just slight variations in design or manufacturing.
A more complete test would involve checking the 'Q' or doing what is called a 'ring' test and even more
for an electronic ignition. This requires special equipment. Therefore, it is best to swap in a known good
unit. They are not that expensive.
Electronic ignition - There is likely a single potted module which includes the circuitry and
ignition coil. If anything goes wrong with this module, replacement is the only option. Once the
wiring and resistance of the secondary has been checked, there are really no addition tests that can
be performed on an electronic ignition module without special equipment. A defective ignition
module will have to be replaced.
So replacing with a known good or new one seems to be the only way of knowing for sure..!
Would the valves cause this too? If i had a filler gauge i would check and see if they needed adjusted.. I Already eliminated everything else as the cause except the valves and carb... Everyone online keeps telling me it the carbs, everyone in the real world (lol) keeps telling me other things that i've already checked. I Guess there is one way to find out, is to take the dang carb off tomorrow and clean it.
Are you going to remove the valve cover and show us a pic of the rocker arms? Can you put up the spec numbers off of the tag on the engine?
Testing the magneto
the spark plug.
winding.
WHERE CAN I FIND ONE OF THESE DARN EXPENSIVE TESTERS!! lol,I remember merc o tronic but they don't make those anymore.
Hi! New guy here.
Try a simple test. When it sputters ,spray some carb cleaner at the carb mount area.If it straightens out,it's warping,and sucking air.
I've worked on a few of these,and they had slight warping problem , when warmed up.
Pulling the choke,or letting off the load, evens it out.
Been extremely busy this year and just now getting around to tinkering with it again. The fuel was leaking trough the fuel solenoid. I Rebuilt the carb (replaced, float, seat, needle) and it was still leaking. I replaced the fuel solenoid with a bowl nut and it hasn't leaked a drop since. The mower runs now. The problem is now that it just periodically sputters like it's going to crap out, than it never does. It also smokes a little out the exhaust when i engage the blade. Does the carb need adjusted? Also, my mower now refuse to turn off with the key!!! lol
Update for those that are having the same problem... Mine was indeed the coil. I haven't had a problem with it since i replaced it with a new one.
Just so you know,
When you engage the blades, it puts a load on the mower which in turn causes the govenor to back off which allows the throttle to open right up.
Same as in your old car with a carb, thomp the foot to the floor and engine runs rich for a moment & blow black smoke for a second or two.
This actually is good as it shows the govenor is working properly.
It will not turn off because you have taken the fuel solenoid off, so replace it or a new seal, and it will smoke a little under load.
the fuel solenoif does not stop the engine normally.
the magneto cut out stops the engine.
The fuel solenoid blocks off the main jet to prevent toxic unburned fuel vapours from ending all life on earth Oh and making the exhaust go bang.
