cprice12
- May 21, 2014
- 29
So late last season the driveshaft popped off the gearbox on my Bushhog ZT25 and burrowed it's way into the ground before killing the engine.
I can only assume I didn't tighten the set screws properly when I had the gearbox off for servicing.
I finished the last couple mows of the season with my other mower (not ideal).
Anyway, I was getting the Bushhog ready for this season and when I had it running, it was severely vibrating...so much so that my feet were tingly for a bit after turning it off. I only ran it for like 15 seconds or so.
Upon inspection, the driveshaft looks a bit bent and has a slight dent in it...I assume from when the driveshaft came off and may have made contact with the frame. The bend is easy to see when it's running, but not so much when it's not...so it's not a drastic bend by any means.
My question is, can this be repaired? Straightened by a machine shop maybe?
OR...
Would it be best to just replace it with a new one?
Here is the part:
Bush Hog ZT-25 25HP Kohler Engine Parts ZT-25 25HP Kohler Engine Driveshaft Assembly (Manufactured By Neapco) 99082 Parts List and Diagram
I'm pretty sure I'd be looking at parts #1 & #2 in the diagram...which would be $600 on this site...which seems crazy to me. I was thinking maybe half of that at most.
I found one a bit cheaper, but this one had the better diagram to show you guys.
Also, can a different driveshaft be used? Or can each one only fit a certain mower? You'd think as long as the Yoke's fit, it would work, yes?
Thanks, as always.
OR...
Here is the part:
Thanks, as always.
