DougMessesWithHisMower
- Apr 2, 2015
- 4
I had an issue last year with my Honda HRX2173VKA mower becoming very difficult to start. I decided to try cleaning the carburetor so I removed the main 2 bolts from the air filter and, unfortunately, the carb and attached gaskets came free without me being able to see exactly which ones went exactly where. I have a parts diagram that I found online that shows an exploded diagram of the carb and gaskets but it is hard to tell which gasket is which. I have 3 gaskets and 2 are very similar but one has what looks like air guide impressions on it and the other one seems to be a different material. The 2 main bolt holes match up for all of them but 2 gaskets have a small hole in them that does not seem to match each other. The engine/carb is for the MAGA-206xxxx series and the carb does not have a drain hole in the bottom. If someone has any specifics or else a good picture on which gasket goes and could post it or tell me where to find it I would appreciate the help.
