al new life
- Mar 17, 2015
- 10
Senior Citizen, I may have confused you with my last post, the original problem was I had to block air, probably due to debris in the carb
then I attempted to rebuild the carb and I lost the main jet because I didn't know what I was doing (I ordered a new jet)
Then i installed a rebuild kit into the carb along with a new main jet, and when I reassembled the carb, I put the choke flapper spring in the wrong way causing the choke flap to be in the closed position
this was a new problem, so practically all my problems were due to the fact that I was doing reassembly on the carb incorrectly
but all is well now, and I am walking in tall cotton as they say
appreciate you jumping in there to assist me,
I might need some more help as I attempt to repair a troy bilt roto tiller
thanks again
thanks again
