Buying a cheap new self propelled mower
I have tried to figure out more ways to save up for a better mower but with everything else we need, it isn't going to happen. I more than likely am going to purchase the Snapper that I mentioned along with a Snapper weed wacker, do you guys think it is worth it over the much cheaper Murray versions?
Also, the B&S 725EXi engine on the Snapper claims that the oil never needs changed, just add and go. Coming from the auto world I do not and will never believe in "lifetime" fluids. Do you guys know if this motor even has a drain plug so I can change the oil? I plan on breaking it in for a couple mowing sessions with the oil that it comes with and then switching to a full synthetic. Next time I go to Wal-Mart ill see if it has a drain plug.
No it does not hava drain plug which maker the engine cheaper to manufacture which is the whole point.
Walmart demand cheaper & cheaper mowers so they can make more profit.
If the Walmart mower goes bang, don't expect any help from Walmart and a frosty reception from the dealer.
Do you really need a SP.
If you are strapped for cash momenatrilly why not just get a bigger push mower for now and your SP latter when you have accumulated some more money for your favourite brand of SP mower.
Yeah im pretty turned off by the neve having to change your oil so i have ruled it out. I did however find a Troy Bilt at Lowes that has a 160cc Honda engine so i am going to go with that. With 10% off coupon it will be the same price as the other mower i was looking at.
Good choice with the Honda engine. :thumbsup:
About changing the oil. I have a lawn boy without a drain plug. What the owner's manual says to do (and what I do) is turn it on its side and remove the filler cap, draining the oil out that way.
Seems to have worked OK on mine.
