Twigs
 - Nov 2, 2012
- Threads
 - 3
 - 25
Got my new Ariens 921029-Deluxe Platinum with the AX 414 engine last Feb. So this is the first real snow season I got to put it to the test. We have had a lot of snow here in NY so i have used it many times.
Well now here is the problem..Today went to use it and it ran for about 10 mins then started to choke then died. It was filled with gas before I started..I waited a few minute and crank on it a few times it would not start, Then I press the Primer bulb a few times then crank it again and it started to run. It ran for about 2-3 mins then choke and died. I then pulled out the spark plug and clean it..it was not to bad with carbon. I primer it again and it started and ran for about 3-4 mins this time. Any ideas what is going on with this. It seems not to be getting gas I think. It's been pretty cold here
