davhendricks
Oil is coming through the muffler. What should I do?
I've seen this happen when the mower is sat on it's side or tipped in a funny way for a while, like in storage. The valve seals aren't perfect and oil will tend to creep around where it shouldn't be. If you haven't ran the mower yet, I would suggest removing the spark plug and cranking over the engine, it may shoot out oil. I suggest this because oil (and liquids in general) aren't compressible and when the piston reaches the compression stroke, if the engine is rotating fast enough, it could cause strain on the connecting rod or other parts. If you have run the engine, just keep running it until the oil burns off, once it does, it shouldn't happen again. If it does, you may just have to live with it or move to a thicker oil like straight 30 weight. The only thing that would cause it really is faulty or heavily worn valve seals or piston rings and in either case, it's a pretty big task to replace those.
And don't forget that most B & S engines do not have a valve stem oil seal on the exhaust valve.
