electric pto clutch.
I noticed that no one has mentioned the bearings. I have had to replace the bearings in the PTO on my 96 Craftsman. The bearings get rusted from the moisture and tend to seize on the shaft. I wonder if the bearings are semi-seized on the shaft and release after a period of run time. The best thing to do is remove the PTO and check it out. This has been a problem on my tractor. The first PTO was completely distroyed. The second PTO is checked from time to time and I replace the bearings as necessary. I got a little extra use out of a set by drilling into the bearing seal (very small holes) two in all and forcing in grease with a needle grease fitting on the grease gun. You pump in one hole until the grease comes out the other.
This may or may not be the problem, but it's worth a check.
My issue is what appears to be pto clutch failure, but only seems to happen when hot. Does that make any sense? Acts the same when direct wired to battery.
Having a similar problem with an Exmark lazer z hp. Ran for 1--17 minutes, then the pto shuts down. Let cool---goes again until next time. Anybody have any ides?
It sounds like an intermittant short in the electric clutch. Is that is the case, get your checkbook out. I don't know what kind of electric clutch you have, but you can take an ohm meter and check the coil resistance. I am having clutch problems right now myself. My clutch reads .2 ohms, when it should be between 2.4 - 3.4 ohms. .2 ohms is almost a short and it will kill your engine.
I'm sure your problem is also the electric clutch. Seems to be a common problem in these "high end mowers." If you look, you can find a replacement for under $200. There is a lot of info out there. Good luck.
Found problems,I hope.
I found broken springs on pulley plate. Replaced it with one from an old clutch I had replaced 2 years ago. I also replaced the battery and checked and cleaned all electrical contacts I could think of. Reinstalled clutch and it started working. Don't know which was the true fix. Now I just need to let plates burnish in. I am glad I found the Forum, and I really appreciate the help. jsr
Is there a current figure during lockup? How much does the ?magnetic clutch? draw when operating properly? Seems that would be a good running measure to have. Also we know e.g., motors which are receiving insufficient voltage can burn up so seems a PTO not receiving enough voltage could slip itself to death?? A person could use a VOM to check this?
Fairly easy to do.
Hook up an ammeter on the + feed to the clutch.
Clutches will pull 5 A to 15 A depending upon model when cold & go by anything as much as 20% when they get hot
