the problem is there is power coating and powder coating and power coating.
The very best stuff chemically strips off the old paint then does a chemical clean followed by any repairs followed an another chemical clean followed by a controlled rusting followed by a powder coating followed by a full furnace vitrification.
In the end you have a part that is like a bath tub where the top coat is chemically bonded to the basecoat & to itself so if it is breached any where there is no corrosion & no lifting.
At the other end is a chemical degrease then a plastic top coat that envelopes the parts with little to no corrosion protection underneath so the first time the coating is compromised it will start to rust between the steel & the thick plastic coating. We have all seen this, cheap garden furniture where the top coat cracks then peels off in large lumps. Think about it as laminating for real objects.
Best by far is an active etch primer either a zinc rich one or somthing like the POR 15 mentioned earlier. So that if the paint is compromised any damage will be limited to the immediate area and not cause the entire coating to lift off after the base metal has become so badly rusted it is beyond economic repair which you can not see happeing because it is happening under the platic top coat.
Now as for doing it yourself the go is a big steel or copper pot on the barby with a boiling solution of caustic soda ( lye to some ).
This will lift all the paint off lift the rust off as well as degreasing in one ( long ) step that requires almost no effort.
Wash the clean part with hot water & blow dry quickly and then paint immediately .
Do not touch the cleaned parts with your bare hands.
You can give the parts a molasses treatment if you are not ready to paint immediately and the molasses ( phosphate ) surface can be painted directly over with no need for anything more then a light wipe with a tac rag.
A pound of Caustic and a pound of molasses will cost about $ 5.00 all up.
Better still is the old solutions can be poped into some old 4 gal plastic drums ( you see them every where on the side of the road ) for future use.
The molasses will stink but is fine . The lye needs to cool then be decanted.
the dreggs in the bottom of the boiling drum with all the crud it has removed can be neutralised with some muratic acid then allowed to evaporate off, The remaining crud gets wrapped in paper & popped into the garbage bin.
