hrdman2luv
Multiple module failures within a short period of time, raises the possibility that you are getting battery voltage to the module, at least intermittently, which could mean a short in the wiring, possible key switch problem that is being caused by vibration and bouncing.
Look at the side of the module where the ground wire attaches, and see if the epoxy is cracked, and you even be able to pick up a burnt wire smell if you put your nose close to it.
I think you're onto something about the key switch. That's about the only other source of electricity that could be getting the kill switch. Except when you consider that I don't get any spark when the kill switch isn't connected either...
BTW, it started yesterday for about 2 stokes. Most of the time, it fires for one stroke. But that's it. It take a few minutes for it to do it again just like that.
