zero turn spins and slides
punchbug
I run a Toro z master it spins and slides when making turns. I have tried to things to prevent it like wider turns and no zero turns with no luck still tearing up lawns. I've noticed it doesn't seem to have a slow speed when I pull back the levers the wheels seem to lock up. Any suggestions maybe mechanical.
What model Z-Master, How old is the unit and have you checked the Hydraulic oil level in the expansion reservoir.
It's a 03 z 500 with 1100 hrs. The oil level is at the cold mark. I haven't checked it hot.
If it's level is good cold I'd leave it alone and not remove that cover when hot. What drives do you have in that thing?
