Shughes717
- Jun 12, 2014
- 1,230
The Ferris dealer is also a Husqvarna, Simplicity and Stihl dealer. I glanced at the two he had on the floor. He had a lawn tractor I looked at earlier in the year - was not impressed so I assumed the rest of the bunch was similar. Maybe I'm wrong.
The mzt is a commercial mower. A 52" will run between $5000 and $5500. It offers the commercial fs series Kawi engine and zt3400 hydros. The snapper pro s125xt has the same drive train with a 61" icd deck in the same price range. You can get a 48" big dog stout with the heavy duty fx series engine and zt3400 hydros in the same price range, but those mowers would be extreme overkill for your needs. Simplicity is geared more for residential use than the ferris. Not made quite as heavy unless you are looking at the champion, or citation.
In the end you know what your budget is, and what you want. Any of the mowers you are looking at will serve you well for many years if you maintain proper service and don't abuse the mower. You don't need to feel like you have to have the commercial drive train. It wouldn't be worth the extra money for your needs. If you have two particular mowers you are looking at in the same price range, and one does offer a better engine, transmission combo then it would probably be a better option. You will probably be putting 50 hours a year on the machine or less, so the residential engines should be fine for your job. If You want to look at husqvarna you may want to check out the mz series. Has a thinner 11 gauge deck and has the fr series Kawi, but they aren't bad mowers.
