Better blades for a MZT 52?
Dave1954
My new MZT 52 is doing a good job with its stock blades just wondering if when they need replacing have others found better ones over stock?
Is there no one on this forum that has any input on what blades do the best cut?
Normally stock blades don't last to long unless there maintained. If your looking for replacement blades I'd go with the Oregon blades, the G3 Gator blades should work and give you a better cut. You may find them in a G5 I'm not sure if there still the residential blade or commercial.
