Snapper101
Has anyone used Pennzoil Multi purpose 2 cycle oil yet? I have almost given up trying to find good ole LB oil. And have tried all the Multi ratio Pro mix and what have ya. So I thought I,d try the Pennzoil which is pretty easy to find around here. It seems to run a lot better on the Pennzoil than the Pro Mix I had been using. One thing I do miss is the puff of blue smoke when you first start it up. The 10201 just won,t do it. My 10424 dura force would always puff a bit at first start. I always thought it was the LB oil.
