Sorry for this very basic question but am I to assume that if the engine cranks but won't start then it must be a fuel problem?  I think I read somewhere that the 2 coil assemblies are  stand alone systems and as a magnet passes across them they will create the spark. So unless they both went bad at the same time, or both plugs fouled at the same time, I could squirt some gas into the carburetor and it should fire? This Scag Wildcat has the 2 cylinder liquid cooled Kawasiki engine. There is 12 volts at the fuel solenoid with the key on.
