Gx325 drive pulley
Kaos646
I have a 2002 John Deere gx325, the crank case gasket is leaking and I need to pull the motor to replace it. I have gotten to the drive pulley and can't seem to remove it. I have soaked it with moovit to get things Loose, and still nothing. Does anyone know how to remove this? Thanks in advance. image.jpgimage.jpg
4" gear puller worked great, pulled the drive pulley off and gasket was easily replaced.
Thanks for replying, good to hear it went well, pat yourself on the back. The information you posted will be most beneficial to others, thank you very much Kaos646, mechanic mark.
