Mower deck Kubota 121S 48" throwing belt
kgw52
Anyone having problem with belt being thrown, breaking?
Ragnar4841
Nope. 55 hours on mine and never had anything like that happen. Though I've never taken the mowing deck off either.
kgw52
Yes OEM and going by The book on operating. I can see belt markings on the deck.
reynoldston
To break a new OEM belt you most have a bad alignment problem. Bent brackets, bent pulleys, bad bearings, broken spindle housing Maybe remove the deck and check out everything very close, like cracks where the bracket fasten to the deck, or worn out bushings and bolts. Did you hit something?
mechanic mark
Good post reynoldston.
kgw52
Thanks
KGW52
