Cambre
cambre
I have a zts7500 craftsman with 26 hp kohler eng. Oil from one of the transmissions leaked out over nite after heavy use. Cannot find info. I need from operating manual. Where is fill plug? What kind of oil do I use? Thanks for any help----Cambre
Do not mean to be disrespectful but I though I stated my problem pretty plain. How do I refill the transmission? Whats so hard to understand?--Cambre
I'm not trying to be difficult, just helpful. The subject that you used is Cambre which doesn't tell anyone anything about what your problem is. To find out what the problem is, the subject has to be clicked on and then the message read to determine what you're looking for help with. I clicked on it because I had no idea what Cambre was and was curious to see if it was anything that I knew anything about. Many people will not go to that much effort. I do not know how to help you with your problem as it's outside of my area of knowledge, but I do know how to find a manual for the engine in the hopes that it may help you, apparently you're only looking for a direct answer and since I can't provide it I'll be on my way.
dewguy1999: Stop & come back. I used the subject drop down & didn't see anything close to my problem. My problem was kind of long so I skiped it. Guess I need to learn how to use the forum. Thank you for explaining it to me. So sorry I upset you.--Cambre
Okay here's what I've been able to figure out from the information in your first message and some leaps of thinking that I've made. According to SearsPartsDirect.com this is the manual for your mower Operator's Manual and it's a:
ZTS 7500
Zero-Turn Rear Engine Rider with Electric Start
Model No. 107.28791 (26 HP Kohler Engine with 50" Mower)
According to page 29 of that manual:
Transmission Type: Hydro-Gear EZT ZC-AHBB-2A7B-1DPX
According to Hydro-Gear.com this might be the manual for your transmission ZT-2100 / ZT-2200 (EZT) Integrated Zero-Turn Transaxle Service and Repair Manual. If this is the correct transmission manual the diagram on page 4 shows where the fill port is and the fluid change procedure is on pages 11-12.
Hopefully this can be of some help to you.
ZTS 7500
Thanks very much dueguy 1999, The zt-2100/zt-2200 looks like the transmission I have on mine. Thanks very much for your time. Your answer is what I needed. Your friend,Cambre
