Legacy XL Reverse Mow Lockout Disable
cloead
Has anyone attempted this? I have to turn my deck off and on million times when cutting my yard (lots of areas without grass still.. and it kicks up a ton of dust if I mow over them). And having to disable the reverse kill each time is annoying.
I haven't dug into it yet but was wondering if anyone has done this.. any advice is appreciated. Don't really need to hear the "WHY WOULD U DISABLE THIS AWESOME SAFETY FEATURE?!??!" comments.. I usually don't have babies crawling around my yard.
Thanks
Post your 7 digit model number. Reverse switch should be disabled when you disengage mower & stay disengaged until you engage mower and then engage rmo switch.
If I engage mower, then hit the reverse mow switch... the light stays lit until I turn the PTO off and then when I turn it back on, I have to hit the switch again. This is the annoyance.
