JD STX-38 13 HP-Kohler Will not start-has spark , year 1998
what to do now?
  • has spark
    Votes: 0 0.0%
  • key is good
    Votes: 0 0.0%
  • out of time?
    Votes: 0 0.0%
  • Total voters
duker
  • / JD STX-38 13 HP-Kohler Will not start-has spark , year 1998
I have a 13 HP kohler turns over, has spark, has compression about 90-95, but will not start. I have change the gas, clean out the carb bowl, It was not my unit. So maybe the person might have sheered the key, maybe out of time. So today I pulled the flywheel off, key was good, but I found two magnets loose so I fix that. That was a easy fix ( I worked in a magnet factory for over 10 years ). (I have to wait for the glue to set 8 hours) Now I need to know where to look at.
How to set or check timing I thought the timing is set by the fly wheel, is it? Anyone have any ideas? thanks for looking and your help.
model CV13S, spec # 21509, CC-398 , ser # 2524802572
Fish
Those magnets would just be for charging only.... Post the model/spec numbers and some more details.
Fish
So what kind of magnets do you all make?
duker
plant moved, it was for your hard drive in your desk top, also GE home electric meter, Speed for VDO gauges-also GM, Ford, Mopar, small motors, B+ D dc power tools,
and more.
