Hi, I'm new to the forum. I have a problem with my mower and was hoping someone on here could advise me.
I have a Snapper LE1433H. The blade belt has broken and with the force has bent the part photographed below. It's a part which is connected to the wheel that helps engage and turn the blades when you pull the lever.
Does anyone know what this part is called or even be able to help with a part number?
Thanks in advance
Thanks in advance
