bt3
Re: Help: Lawn-Boy 21" SilverPro Series, 10247, DuraForce (2-cycle) behaving badly
Not bad! :thumbsup:
It probably helps that here in Michigan it only gets used for about 6-months out-of-the-year and in my case, once a week where it only gets started once and run for about a half hour. I'm sure the minimal use helps to extend it's life.
It got me curious, so I looked it up in the Service Manual and in Lawn-Boy's own words, it's "about 5 degrees" BTDC and "about 28 degrees" BTDC at "about 800 RPM". You've got a pretty good memory.
Not bad! :thumbsup:
