bobthewoodbutcher
- Aug 22, 2014
- 44
I just got my "new" RER and since I have never used or owned a rider I have a lot of things to learn
It is a 3012x6S
I finally found the model # on a label on the battery holder. All the sites said it would be on the rear of the mower. I contacted Snapper and they said it was a
03 model. I do not think it is that new.
It is definitely not Hi Vac. It throws grass about 12 feet out the chute I need to figure a way to make this a mulcher without breaking the bank. the local repair shop said to just put a metal plate in the chute. I think it would have to curved to the same diameter of the blade to keep the clippings moving. Also, there is a long bar that directs the clippings to the chute. It
it appears that this would prevent the clippings from re-cutting. Any suggestions?
What blade would you recommend?
when i search the web I do not see a mulching adapter kit for my model. the kits i do see are way too expensive. I have some thoughts on how to rig a mulching baffle but I wanted to solicit some from those of you who have been through it
It is a 3012x6S
