Deck probs!
mcy
Will not mow level no matter what. Can anyone tell what adjustment to make.Have tried everything.Has anyone else had this prob?
Couple things to check.
Make sure left and right tires have the same psi.
Turn the blades so they go left to right.
See If the tips of each blade lines up with the blade next to it.
One blade might be sitting higher or lower then the others.
Is a blade bent ?
Make sure none of the deck lift chains have twisted. I had one do it just from the raising/lowering of the deck. Had to jack it up and get the weight off the deck a tad while I rolled the link around until the deck set square from all corners. Lucky only one was out of whack.
