Green Flamingo
Dear Green Flamingo and Hank Koster -
I have the exact problems that you are having with your John Deere lx188. I have replaced the dirty fuel filter and checked the fuel lines. The fuel lines look in good shape but, how do I know if air is getting into the line that connects to the fuel tank? The fuel line after the filter that connects to the carb seems bone dry. I hope that you have solved your problems and can share your remedies with me. Also, Fish, how do I adjust the valves?
Many thanks
Leah,
Happy to say I have resolved the problem. After eventually replacing the fuel pump as well as cut the plunger off of the Solenoid, it was still doing the same thing. Surgeing and finally unable to run with the deck engaged. Since I'm not very confident taking apart little carbs, I took it to a mechanic I know, who took out the needle valves and soaked it all in combustion chamber cleaner for a few hours. Runs like a scared rabbit now.
I will say this: The govenor is extremely touchy on this machine. It can be adjusted by moving the plate that houses the throttle cable etc. One of the bolt holes is oblong. Just move it so slightly, tighten it and try it. If it's idling too fast or slow, do it again until you have what sounds like normal rpms. It may take a half a dozen tries.
Also, the fuel filter does not run full. At least on mine. Half full at best and this IS normal.
If you haven't removed the carb it is a bit of a pain. You will have to remove the bonnet, (there are two bolts on the sides which will require an extension), and then the black metal plate behind it (two small 10mm nuts) In fact everything in that area is 10mm so you won't need a bag of wrences. The carb mounting nuts are on the same bolts as this plate is attached to. In order to remove the carb you will need to remove the two bolts that hold the plastic air duct in place on the blower housing, which is attached directly to the carb intake, then VERY CAREFULLY, remove the throttle linkage plate and the carb at the same time slowly. You will have to remove the spring going to the govenor and finally the two little armatures that go from the throttle linkage plate and govenor to the carb itself. The one coming from the Govenor will have a little spring on it as well which must be removed at the same time. Pay very particular attention to what goes where. (I wish I had have taken pictures before - but you would be wise to do this) The choke linkage one has a bend in it so be sure you know which end goes where for reassembly.
Once you have the carb cleaned and reassembled, just reverse the process you used to take it apart. If you have any amount of dirt in there, I would also recommend pressure washing that area out after you remove the plate and before removing anything else. Things are very hard to see otherwise if they're covered in years of gunk. Do that before you take anything apart.
You may actually have to remove the govenor armature as well (I did in order to get the spring and connecting rod off and on) There is a hole in the govenor shaft from the engine. I marked the govenor lever with the hole position before I removed it and replaced it in the same postition.
So what have I learned from this 500.00+ exercise? It was not the plugs, or the coils, or the filters, or the fuel lines and it was not the fuel pump. It was a dirty carb all along. The first guy I took it to removed the bowl and said it was clean as a whistle. WRONG. It needs to come apart.
In any event, I have now what would be for all intents and purposes a brand new machine.
Oh, and the valve lash (which I did not do), is .06. You will need to bring each cylinder to TDC, and then adjust the lash with a feeler guage just so it pulls out with a slight resistance. To find TDC without tearing apart the whole shamoozle, just remove the plugs and click it over until the piston is as close to the spark plug hole as possible. Do this seperately for each cylinder. But honestly, unless they are making a lot of noise I think it's best to leave them alone.
I don't recommend dissasembly with a hot engine. When you take the fuel line from the carburetor, there could be a lot of fuel loss - directly on a burning hot muffler!
Hope this helps some. It is extremely frustrating. If you need anything more please do not hesitate to reply.
Cheers,
Rick
