bt3
- Aug 22, 2014
- Threads
- 5
- 249
I know that I need to, but since I don't the necessary tool and material I've never cleaned my Lawn-Boy's exhaust port and it still runs fine, I must be lucky. Any particular brand of synthetic? Does it need to be 2-cycle synthetic? Is it mixed at 32:1 or a different ratio?
Most Synthetic brands come from the same root company, like Shell Oil, so I don't worry about a particular brand of Synthetic. Yes, it needs to be 2 Cycle Synthetic. Most stores that carry 2 Cycle engine oil also carry the Synthetic 2 Cycle. I got mine at a local Sears Hardware.
You can run 2 Cycle Synthetic a little leaner than 32:1, but I do not. I still run it at around 32:1, sometimes probably closer to 30:1.
You are lucky if you have never cleaned your exhaust ports or muffler and yet you are running fine. I made the mistake of running a cheap grocery store brand "Arnold" 2 cycle oil that I actually bought at a grocery store. l had some issues with carbon with this brand. Also, in a pinch one time I ran 2 cycle "Stihl" chainsaw oil at probably 40:1 (maybe more) and that really carboned the machine up big time. Even when running the original LawnBoy "Ashless" oil at 32:1 I had issues with Carbon in the exhaust ports and muffler. Since running Synthetic, I no longer have these issues.
I don't mind working on my LawnBoy. I actually enjoy it. But the job of cleaning the carbon out of the exhaust ports and the muffler is just gosh awful messy. I've seen people clean these mufflers (NON ALUMINUM!) by putting them on an outdoor gas grill and burning the carbon out that way under very high heat. I don't do this. I scrape out the black carbon and then clean with solvent to make sure it is very clean. That is a messy job no matter how you slice it. I'm hoping that Synthetic will cut this process down to once every two years. With regular 2 cycle oil, I was doing it at least twice a season.
The only good thing about having to clean the exhaust ports and muffler is that you are forced to take the blade off, so it gives you an opportunity to sharpen and balance the blade as long as you are removing it. Other than that, it's a very messy job unless you are burning the carbon off.
