Rschultze64
I am sure that I can hear the starter spinning. It just seems that it isn't engaging. Any help would be appreciated. Thanks in advance.
Check voltage on battery should be high 12 or above.
Voltage is 12.2 and I tried tapping the starter while trying to start. Nothing changed.
Clean the starter bendix then lubricate it. Only certain lubricants can be used as many will gum up the bendix and make the problem worse. I use graphite lube in an aerosol can. Works great for me.
