rrichtarek
- Aug 19, 2014
- Threads
- 1
- 5
I have an 8hp Wisconsin Robin EY27W that my son and I have rebuilt for a go-kart. The good news is that it started on the first pull. The bad news is that at high RPM it misses and will backfire when you back-off the the throttle. I've spent conderable time trying to remediate this issue through carb adjustments (it's a NOS carb). I took the spark-plug gap to .28 and that seemed to help a little. Now I'm onto timing - new points/condenser were installed during rebuild and set to .14 per service manual but I want to be more precise. My question is where do you connect the hot lead on an inductive timing light? Do you need to? (haven't tried yet)
