Badboy
Hey giys I have a few hrs on the badboy ! It's great but I did remove the homemade stripper it just didn't work the kholerbis a beast the mower construction is very stout ya know it will cut like carpet since I can't get the stripes I want I Gus I'll just please it alone
Wow! Guess I don't need to type after taking a ambient! Spelling sucked . I raked the deck 1/2 inch is that enough to get stripes? I made another stripe strip a different length I'm not giving up just yet
I bought a 2014 CZT 60" with the Koehler Confidant ZT740. I picked her up in May and have ~30 hrs. Previously I had a 50" White Equipment ZT. The 2.7ac I cut used to take ~130 mins. Now I'm at 55 mins. I up graded to an Exmark suspension seat, best money spent since I'm running full out 90% of the time. I've got another 5+ ac that I'll cut once a month and it's around 20" tall. I have to slow down but it get chopped up and spit out w/o an issue.
At 4 hrs I changed the oil and at 15 hrs. I have a long history of small engines and the first 2 oil changes are key to longevity. I switched to a full Syn at 15hrs. Bad Boy added an extension to the oil drain plug so it easy access and drains w/o mess to a pan below. Nice little feature. The Koehler is broken in and feeling stronger. It has enough torque that front wheels are easily lofted when full throttle and full forward is selected quickly. Watch out on inclines since the 11 gals of gas helps move the CG aft.
The electric deck is handy and allows easy adjustment on the fly. 11 gallons of gas allows me me to cut 15+ac without an issue. Due to being somewhat vertically challenged, 5'9", I got tired having my feet flopping around. I picked up a 8" rubber wheel chock from TSC, cut it in half and mounted them on the floorboard. Works great for me, cost under $20 total.
Overall I'm quite pleased with the form and function. Being the Engineer I am I have added some little extras just to avoid future issues. Where wires, cables or lines run and may chafe I added some Teflon spiral wrap or wire harness covering to protect them. The seat catch was not easily accessed so I added a length of Paracord to allow me easy release of the seat. The tilt up floor makes cleaning the top of the deck easy. Actually when compared to my White Equipment, this deck doesn't seem to trap grass and get it compacted and mess things up.
All in all it's a well built powerful ZT that handles great and hauls butt! The suspension seat is well wort the $'s! The value and build is good enough I'd recommend this unit to friends.
Later
Neil S.
I have a 2013 MZ 42" w/ B/S 19hp purchased May 2013. I went with the 42 so it would fit through my fence gates. Mowing just over an acre.
Review:
In retrospect, I wish i had've spent the extra 700 and went with the Kaw. The only reason I say this is that I cannot mow at full speed if its been over a week or so in my thickest parts and damp, but really that's just me being lazy. It really does supply very ample power for residential mowing. Even with only a 540cc - it provides enough torque to bring the front wheels off the ground several inches. YES I know this damages the trans. First ZT - I learned quickly in the dealer parking lot!
Deck DOES scalp if you have a lot of high spots. I've learned my yard pretty well, so I know how to hit them so that the anti scalp wheels hit the high spot, but the first few times I definitely dug. The solid deck does provide the advantage of the fact it is ROCK SOLID. I hit a stump going full throttle mowing and it hung. It did absolutely no damage, as verified by my dealer. Blades were still completely balanced. I've nearly destroyed a Deere floating deck doing something similar before, and it was a much slower mower.
Someone mentioned the sand grit foot rests. I mow once twice a week for a season and a half and it shows no wear. The deck seems to get a high amount of discharge buildup. Ive removed the outfeed shoot on mine as i like it to distribute the clippings further, and that helped some. I usually clean it with a pressure hose every few weeks and spray a good coat of cheap olive oil under. It is a big help. Paint is scratched in places, but to be expected with ad many trees as i have to mow around.
Biggest complaint sounds silly, but NO CUP HOLDER?
I use conventional oil - changing about every 50 hours. A little fast, but oil makes the engine.
I do have one issue where, since new, the mower seems to track to the left when bars are both fully engaged. Maybe someone can give info on this?
About a month ago I had a SEVERE issue. I was mowing for about a half hour when the engine started to sputter and blowing plumes of smoke. I disengaged the blades, sat a minute with the engine at half throttle and it stopped. I continued on, this repeated several times. I thought at first I had over filled the crank case a bit - but it had perfect fill. I looked down to see the block had split at one of the engine mounts.
My dealer came and picked it up and shipped it back to briggs. They inspected the block and found it to be a defect in the cast. Engine was promptly replaced with a brand new Intek 19hp under warranty. This isn't really a bad boy issue, but worth mentioning.
STRIPING:
To get great striping you could go spend tons on a SCAG Tiger Striper... OR build one. I'm sure I'm not the first to do this, but in case youve never seen it done heres one way to build it to use the hitch on a BadBoy (or any pin hitch) without drilling mower.
Materials:
-3-4" piece of PVC schedule 80
-two end caps
-4-6' steel cable
-two grade 8 1/2" bolts, nuts, lock washers
-24"x2"x1/4" flat steel bar
-4 bolts/nuts of any size
-2 large washers
-sand
Drill hole diameter of hitch pin in center of bar. To the left and right, drill two 1/2 holes so that the edge of the hole lines up with the bottom plate of your hitch. Looking from above this would look like o\o/o on most hitches. Put the grade 8's in the outer holes. This will keep the bar from turning when the pin is in. At each end of the bar, drill holes the size of your cable (at least 1/4").
Drill holes the size of the cable 6" from each end of the pipe. Feed the cable through the hole, then through a washer so that the washer is on the inside of the pipe. Tie the end around one of your extra bolts & tighten a nut on it so that the bolt is against the nut is against the inside of the pipe. Do this for each end.
Glue on one end cap, fill the pipe with sand, now glue on the other end. The result is a heavy piece of pipe with a cable sling on it. Pressure from pulling on the cable is against the washer.
Now cut the cable in the center.
Attach bar to mower hitch.
feed the cable through the ends of your bar so that the pipe is dragging the ground with little slack.
Wrap around a bolt and tighten as before. No washer needed as it won't pull through the PVC like the other end can.
now. you have a quick detach striper that will perfectly bend grass.
Mow the same direction for a few mowings to "train" and it will look good as Wrigley.
Hello all,
New to this and shopping for a ZTR and I was leaning toward the BB but after see the NAEDA report and reading the comments here I think I will pass on the BB. I had not considered the Gravely
but I will now.
I am an old East Texas boy and now retired in Florida (Melbourne area) any suggestion appreciated.
Thanks
Audie
Hello all,
but I will now.
Thanks
Audie
What kind of budget are you looking at and what dealers do you have in your area? How many acres are you mowing? Are there obstacles such as steep hills, ponds, fences with small gates?
Thanks Shughes for your reply,
My budget is modest about 4 to 5 k. I just this minute got back home from visiting a dealer in Palm Bay Florida (Palm Bay Power Equipment ) and I am sure I have made my decision on the Gravely. Thanks to Danny the owner, I know more after a hour visit with him that I have learned in the last 3 months.
My wife and I are building a new home (Builder is starting on lot work now) it is on a 1/2 acre lot and no obstacles or gates as of yet but I will be buying the Pro Turn Model 991201 52". The Dealer will put on a optional suspension seat for me and I think I will have no fear of buyers remorse with this ZTR. The home builder will not finish our home until Christmas or mid Jan 2015 so I will have some time to shop price and learn some tips from this forum about maintenance issues. As soon as the homeowners association is turned over to the owners, I will likely take over care of the common areas and maybe a couple of neighbours yards to help offset a little cost and go from there as I am retired now and a little side job would cover some of my home brew beer cost (whoopee}
Audie
Thanks Shughes for your reply, My budget is modest about 4 to 5 k. I just this minute got back home from visiting a dealer in Palm Bay Florida (Palm Bay Power Equipment ) and I am sure I have made my decision on the Gravely. Thanks to Danny the owner, I know more after a hour visit with him that I have learned in the last 3 months. My wife and I are building a new home (Builder is starting on lot work now) it is on a 1/2 acre lot and no obstacles or gates as of yet but I will be buying the Pro Turn Model 991201 52". The Dealer will put on a optional suspension seat for me and I think I will have no fear of buyers remorse with this ZTR. The home builder will not finish our home until Christmas or mid Jan 2015 so I will have some time to shop price and learn some tips from this forum about maintenance issues. As soon as the homeowners association is turned over to the owners, I will likely take over care of the common areas and maybe a couple of neighbours yards to help offset a little cost and go from there as I am retired now and a little side job would cover some of my home brew beer cost (whoopee} Audie
That's a lot of mower for half a acre.
I would save a couple grand and get a mower made more for your needs.
If I only had a half acre I would just get a push mower or at the most a snapper rer.
