Nwatson99
I will kick it off, I have the Z960R and like for multiple reasons which I will list below, but the most important thing that sticks out is the superb cut and striping of this machine. I change mowing directions each week so after I cut I have stripes in my yard and when I do change directions I do not have the stripes from the previous cut still trying to blend in so dominant from a machine with a stripe kit on it that it looks like crap like it does on many yards I have seen from mowers using the striping kit.
Others things that led me to the JD Ztrak series are:
Stamped 1 piece 7 Iron Deck
Deck is hung by structural bolts and carabiners
Hydraulic deck lift on control lever
Emergency deck kill switch on other controller
Deck height adjusts with a dial, no pins or levers
Foot pedal e-brake
Cross Porting hydraulic system
So what JD mower do you have?
Foot pedal e-brake
