Engine Cub Cadet SLTX 1054 Kohler Engine courage 26 j1940 HP 725cc Oil Light
Marryann
With the engine running, the oil light comes on for about 30 seconds, then goes off and after 30 seconds, comes on again --- on and off ----- what causes this???
The oil is full - I changed oil filter and still does the same thing --- Yet, the engine runs fine.
Where is the oil pressure transmitter located on this engine. Thanks for the info.....Maryann
With the engine running, the oil light comes on for about 30 seconds, then goes off and after 30 seconds, comes on again --- on and off ----- what causes this??? The oil is full - I changed oil filter and still does the same thing --- Yet, the engine runs fine. Where is the oil pressure transmitter located on this engine. Thanks for the info.....Maryann
This is telling you it is time to change the oil. It will do this every 50 hours.
Should stop after you log in a hour.
