specialkev
I have a 2013 model Dixon SpeedZTR 30 mower. Recently the blade belt has started to fall off when the blades are disengaged quickly. If I disengage slowly (10 seconds or so), then it does not slip off, but that's a huge hassle when needing to repeatedly stop to get rocks and branches out of the way.
The belt always comes off of the pulley directly under the motor. Never off of any of the deck pulleys. I'm getting more irritated each time I mow and I'm not sure what else to do. The belt is brand new (replaced because the old one was falling off so I assumed it was the belt and replaced it) but that didn't solve the problem.
I'm not sure if something is out of alignment on the deck or what. I can post pictures as soon as I know what would be helpful to see.
Many thanks in advance.
