Running double blades?
Sonders
Read on some other forums about guys running double blades on their mowers to create better lift which led to a better cut quality. Are any of you running double blade setups on your Hustlers? I'm curious and considering giving it a try. Wouldn't be out that much $$$ on adding another set of blades onto the mower to try it out. Any input?
I run doubles on my Cub. It adds an extra 1/2 inch to the cutting height. In other words, cuts the grass shorter.
Used it last fall when picking up leaves had much less clogging of the chute. Also seems to have less clogging with wet grass also.
Don't remember which is on top, the high lift or mulcher. (use both)
I had just enough thread left on the spindle to tighten them down. The spindle end barley makes it to the end of the nut. You "may or may not" have enough thread to support two blades, Just an FYI for ya.
It does take them a little longer to "spool up". So I start them with a slow throttle. And the very first start of the day (cold spindles) I can tell the difference.
I keep the spindles really greased up with Red & tacky.
Great info GeoJB, thanks. I figured I'd need some longer mounting bolts for the blades; the stock ones are pretty short. I know on my old Turf Tiger it was recommended to engage the pto at less than full throttle to save wear on the clutch; I guess that woulda kind of apply in this case too.
