Encore zero turn fuel issues
Dmower87
I am having issues with my 20hp liquid cooled Kawasaki engine, I mowed with it and then I put it on the trailer and then it wouldn't start back up I replaced the ignition switch but have no power to the fuel pump my fuel solenoid clicks saying its open and I have spark and it cranks fine, if I hard wire the pump to the battery the mower works perfectly just don't know were to go from hear frustrated. Thanks for any advice
I assume it has an electric fuel pump. Is there a fuse? Maybe a faulty safty switch. Also, because you can hear the fuel solenoid, doesn't always mean it's working properly. gregjo1948
Fuses are all good i dont inow what safety it could be since it runs fine hard wired in i have been trying to trace down any loose wires there may be just going to see what happens tonight
