Trot-Bilt 42" Bronco
DollyDimple
I have bought the above Bronco 2 months ago, and When I purchased it and had a demo, it was not mentioned that the machine would not cut in reverse which is a real pain!
what do I have to do to get around this problem?
Kindest regards
DollyDimple
Look for switch that gets activated when you move to the reverse direction. It is normally down close to the transmission, and should be a single wire. Unplug it.
Thanks for that Ilengine, just going out to garage and try that, will let you know how I get on.
DollyDimple
DollyDimple
Ilengine,
Just done as you said and was very easy as I had to remove the rear wheel to get yet another puncture repaired, 4 in two months not bad going! I have a Blackthorn hedge alongside a small river which is my bounadry and the thorns are 2" long and as hard as nails.
I owe you a pint if you ever get to Ireland.
Kindest regards
DollyDimple
