mycoolhamm
Well i went to mow my yard for the 1st time this year and the damn thing wont start. So heres everything i know to tell you for some possible insight into my problem.
This mower was given to me last year by customer of mine. Troy Bilt 6.75 hp selp propelled no choke/prime. he said he only used it a couple of times.
When i got it, it started fine. Then one time i was mowing and it started smoking really bad. Im pretty sure he had the oil too high and it spilled oil through the air filter. It still ran but smoked a bit. Im not sure if that is related to the current problem. When i tried to start it today it would just run for about 3-4 seconds and then cut off. I notice that i could keep it running if i kinda bounce the mower up and down/shaking it. I took the big orange plastic cover off the motor and there is a little arm that moves independently. it attaches right above carb and then goes in a hole. i notice if i grabbed this little arm and moved it back and forth that i could at least keep it running. I think its most likely a carb issue. do you mower pros agree.
