Guess Which Zero Turn I Am!!!!
gfp55
My model # does not have a Z in it. I weigh 1287 lbs with my deck on and no fuel in me, add a full tank of gas and I weigh 1363 lbs. I have a 7 gauge deck welded deck. I have three blades. I have 31hp. My battery has 400 CCA. Can you guess which zero turn I am?
Nwatson99
Well you are the wrong color for sure then. LOL
gfp55
I have a max forward speed of 12 mph and I am rated to tow 250 lbs. I have a suspension seat with arm rests. I am not green & yellow. Sorry. I do not have a X in my name.
gfp55
My model # does not have a Z in it. I weigh 1,287 lbs with my deck on and no fuel in me, add a full tank of gas and I weigh 1,363 lbs. I have a 7 gauge deck welded deck. I have three blades. I have 31hp. My battery has 400 CCA. Can you guess which zero turn I am?
I have a Kawasaki engine. I have a foot operated spring assist deck lift. Blade tip speed at 3,600 RPMs is 18,413.
Nwatson99
Dang it man, there are quite a few to think about just come with the info and photos. :biggrin:
gfp55
Ogura GT3 clutch/brake 200 lbs Transmission/drive; 2 axial piston pumps, 2 fix wheel motors. Mowing height 1"-6", 66" cut. I should be honest and say I was made from 2009-2012, I was not very popular so I was discontinued. I am not on the list above.
