Mike Koczan
- May 29, 2014
- 6
I bought a used craftsman LT2000 and changed the spindles and I discovered that it had a shorter belt on it than it should have this caused the blades to not disengage when I disengaged the lever. I put the new belt on and now when I engage the blades smoke comes from under the very front pulley that is also connected with the transmission belt this pulley gets hot and so does the left side guide pulley (it gets extremely hot!) any help? The mower does not smoke when the blades are not engaged. I think the guy I bought it from had it rigged to work with the shorter belt but when I put the new spindles on I messed up the rig he had on it I just need to get it working proper. Thanks in advance for any input.
mike
mike
