Won't do anything when I turn the key on; has a new solenoid on it already.
James Slater
After mowing, I washed the mower with a hose and now it won't do anything; nothing when i turn the key on, blade deck won't move. Can anyone tell me what to do to fix my
ZTS 7500 Craftsman zero turn mower. THank You
Allow it to dry a day or two then squirt WD-40 into each safety switch and operate them a few times. Also any electrical part that may have gotten water in it and ignition switch. The next time you have the uncontrollable:laughing: urge to clean it, vacuum it off so debris isn't forced into nooks and crannies and then wipe the parts down with a damp cloth that need to be show room clean.
Having a problem find the safety switch; my manual does not clearly show it on the wiring diagram. HELP:laughing:
