imgood56
I am currently repairing a Simplicity 38 inch cut model number 163914 lawn tractor, when I got the tractor the solenoid had been taken out and none of the wires had been labeled. I ordered a replacement solenoid part number 1686981 and the instructions that came with the part are less than useful, I have looked at the wiring diagrams and they show that the large red wire from battery and red wire from the circuit breaker goes to post B, the the large black wire from the starter goes to post S, the yellow wire goes one of the tab, the black wire goes to one of the tabs. All well and good except the solenoid I received has the right most post labeled A2 with no other labeling on the solenoid.
I have labeled the posts and tabs 1 - 4 hopefully someone can tell me what wires go to what post or tab.
Thank you
Gene
Thank you
Gene
