LT 2000 aluminum transmssion varidrive belt replacement?
ssd
  • / LT 2000 aluminum transmssion varidrive belt replacement?
Has anyone come up with a way to replace the drive belts ( two of 'em, one, 91 inch 21/32" wide V belt for motor to varidrive pulley other 41 inch V belt around the varidrive/ tensioner / tranny pulleys) on this old turkey: MTD made/Sears sold 20 hp B&S engine about ten years old). The owner manual indicates that it's too complicated for a home owner & the dealer wants $190 to replace them. The belts themselves cost about $10-12 (both) if you buy 'em from vbeltsfor less - about one fifth as much as Sears wants for them.
gfp55
Post your model# serial# off the tag please.
Carscw
First thing are the belts oem or some clone?
Try taking the belt guides off the variable speed pulley. If I remember right you have to take the shift lever bracket off.
You can go here. And enter the part number. If you don't have it you can go to find models like mine.
http://www.mtdparts.com/equipment/m..._-mtd%20part&gclid=CNeo8-6kwL8CFRJk7Aod-gcAcQ
ssd
I've figured it out ... the 21HP variation speed, 46 deck Model No. 247.288851ä Craftsman owners manual said that belt replacement couldn't be done by owners & MTD/SEAR's designers didn't allow enough clearance between the tractor's´ sheet metal frame and & its under-seat tranny/varidrive system to pull either of its belts off . I finally decided to remove rear axle /tranny combo (8 bolts altogether - two each at end of the axle up through through spacer & upper clamp, two short horizontal, self threading bolts through the side of the frameç—´ sheet metal "box" just above the axle clamping bolts which connect the varidrive/tranny assembly to it & two more which clamp the front of the tranny to a sheet metal frame crossbar: To actually replace belts, I 1st disconnected the tranny belt tensioning spring from the driver;s side sheet metal frame by tying wire to its hooked end, wrapping the other end around a wooden stick to protect my hands & pulling to unhook the spring from the frame): 2nd: removed the seat & battery support straps, jacked the tractor up off the wheel/axle/tranny combo & reached in from above to slip the belts onto pulleys. The t 41 belt went in OK but seemed to be a bit tight (maybe has a deeper V than the original which was too chewed up to tell). The next problem was that my new 91 inch long (outside measurement) vbelts4less main drive belt was definitely too short to replace the 90.8 vbelt described in the Sears owners manual because the OEM belt apparently (the original was too chewed up to tell) has a shallower-than-standard "V" which renders its inside length longer than that of "90.8" standard configuration belt. I also noted that this machine's drive/clutch tensioning system is poorly designed because both of its pulleys are flat bottomed - one should be V shaped. I went back to vbelts4less looking for Sears no 954 4067A & found its apparent equivalent under ”cub cadet , no. 754-4067 (no A) for about $19 plus shipping. Finally, I then looked for/found a new "MTD Cub Cadet Toro OEM Replacement Variable Speed Belt 954-0467A 754-0467 from pantanopowerequipment on eBay for $16.95 - free shipping -which I've ordered.
The source you suggested http://www.mtdparts.com/equipment/mt...FRJk7Aod-gcAcQ sells the same belt for $36.99 and Sears wants $42.
This Craftsman lawn tractor is a very poorly designed machine because the belts of any sort of belt-equipped equipment should be simple/easy to replace. That weakness is tacitly admitted by the owner'smanual (i.e., you are supposed to pay your dealer roughly ~$200 to replace its drive belts) but is unlikely to be noticed until the warrantee is gone. The home owner/customer's roblems are compounded by fact that the USA doesn't require manufacturers to adopt a rational (standardized) belt description system which makes buying a much cheaper generic replacement part difficult.
Carscw
Man that's a lot of work.
I asked about the belts because MTD uses their own pitch.
I always get my belts off eBay.
The dealer wants $120 for my toro belt
eBay $42
If you have the unit I think you do, there is an easier way to change the belts. There should be two bolts on the back left side of the frame. If you loosen them the variable pulley will shift away from the frame, so you can change the belts.
Carscw
I think I watched a YouTube video on doing it like this. But was not sure.
ssd
Thanks much - isn't in a shame that the owners manual doesn't mention this? -
piochrobert
Glad i found this site and your post, i have craftsman lt2000 2010model 247.289050. It has two belt's and mtd and sear's couldn't even find the second belt. I was beginning to think they sold me the wrong mower. The spring broke somewhere and i couldn't find where it goes, still don't know yet, but on the right track now with your post. My owner's manual say's Hydrostatic Transmission and don't know if that's the right owner's manual. At least now i'm on the right track. Like you said 194.00 to change but that includes the belt's. I think they sold me tractor with wrong trans.
If you have the model I think you do, read my previous post, about a trick to make it easier. Also post your model number located under the seat.
