I found some Raptor dealers around, will check them out. Where can I read on how ZTR's actually work? You talk about tranny, steering, etc. I know in my tractor I have hydraulic deck lift, I have separate hydrostatic tranny and power steering.
I have some wet spots in a yard, mowing them with a tractor done best if I move fast, I did get suck once... How is ZTR's in those "swampy" areas? What about cutting wet grass? I don't get into wet grass with my tractor, but I see pro's doing it just fine. Rarely I see clumps on my neighbours yards...
Ric is correct, this <3k Raptor is probably maximum I want to spend. They do 0% which is excellent too. Do those dealers negotiate like car dealers do? What kind of price off from MSRP I can expect?
Paying pro's to cut is basically every week. But I cut less(I think). When grass growing I might cut every 5 days or so and in a middle of summer I may cut once in 2 weeks. I use tractor 20hr per year MAX. I do think I may need bagger as well as it may help with leafs during a season.
Going little off-topic, what is the best preferred way to take care of leafs? I have big trees and as I mentioned takes 4hr non-stop blowing with backpack Makita (4 cycle) that I have. I blow leafs into piles and then use tarp to move them to the street. I see pros doing it both ways. Some people use blowers, but some use mowers, If it's done regularly (every week) than not much leafs left after cutting. Does that sound correct? Will I be able to do it with Raptor?
