Shughes717
If the hill on your property is steep a residential ztr won't handle it well. What you are being told is spot on. If you want commercial cut quality it will cost more than 2k. Commercial mowers come standard with high lift blades and the blade tip speed is much faster than residential mowers. If you find a commercial mower for 2k that is in good shape it is probably stolen lol. Even the semi commercial snapper pro s50xt will cost around 4k new. With only 3/4 of an acre there may be a small deck (36 to 42" deck) commercial ztr in the 3 to 4k range.
