Just bought an older F935
billymagg
Just bought an older F935 from a campground where I volunteer, had to replace the front PTO shaft bearing bolts that are welded to the frame, and several of the deck belt pulley bearings. I am finally getting to use the mower, but I would like to trade the 72" deck for a 60" inch deck in similarly good shape????? I am assuming the PTO gearbox on top of the deck is common to both decks???? thanks billy magg
I have a 935F that I purchased used with a 72" deck and traded that deck for a 60" rear discharge. There were no issues in the swap. The Yanmar diesel in indestructible. Living proof is 3800 hours on the meter. Hope you have as good luck as I have had.
That sounds like a great swap, and I would love being able to get up close with-out a discharge chute on the side, thanks gopher, I'll keep my eyes open.... billy.
