Hustler Fastrac HD ride SUCKS
Micko
I see no need for any of this.
So with all this not feeling the bumps people will mow faster and then ask why does my mower cut like crap.
The mower is still hitting the bump and or holes so the mower is still feeling the abuse.
Just my 2 cents.
You can only mow as fast as the deck and engine will allow! If your cutting a lot off then you'll have to slow down whether you have suspension or not.
But if regular cutting over rough ground, you can mow much faster.
I went from a Super Z non suspension (just the seat) to a new Super Z with flex forks and seat and well, its night and day!
Flex forks can cause a few problems though. For one, you need to slow down steadily before a turn or the front will dip. This can be counter acted by feathering the deck.
Mowing across slopes you can get more of a terraced look but I used to get that with the old machine so how much difference is really unknown.
If you drop a wheel into a whole you can get a bit more scalping than a regular fork. But you still get that scalp either way. Again, feather the deck!
I had my doubts about Flex forks originally but I have to say, I was wrong about them. Far less trouble than I thought they would be!
One other thing about the abuse, the suspension is between the frame and the ground so in fact, its better for the machine than not having them. Less jolting impacts on the front! Rear is another matter though for sure!
Carscw
You can only mow as fast as the deck and engine will allow! If your cutting a lot off then you'll have to slow down whether you have suspension or not. But if regular cutting over rough ground, you can mow much faster. I went from a Super Z non suspension (just the seat) to a new Super Z with flex forks and seat and well, its night and day! Flex forks can cause a few problems though. For one, you need to slow down steadily before a turn or the front will dip. This can be counter acted by feathering the deck. Mowing across slopes you can get more of a terraced look but I used to get that with the old machine so how much difference is really unknown. If you drop a wheel into a whole you can get a bit more scalping than a regular fork. But you still get that scalp either way. Again, feather the deck! I had my doubts about Flex forks originally but I have to say, I was wrong about them. Far less trouble than I thought they would be! One other thing about the abuse, the suspension is between the frame and the ground so in fact, its better for the machine than not having them. Less jolting impacts on the front! Rear is another matter though for sure!
I still say it is a waste of money and not needed.
DK35vince
Then take the beating and don't get it.
Me I'll stick with my suspension seat , flex forks and smoother ride.
Carscw
Then take the beating and don't get it. Me I'll stick with my suspension seat , flex forks and smoother ride.
Did not mean to make you mad.
I just never have used any type if mower that that have me a beating.
Micko
I find that pretty funny really! Do your ride ons have springs under the seat? Why? Technically, there not needed! But there worth having there arent they!
No, flex forks arent technically needed but man, they do improve the ride!
Does anyone technically need full suspension seat to operate a mower? No they dont but, how much better is the ride compared to the old cheap springs! Chalk and cheese brother!
Waste of money? Hmmm, NOPE! Well worth the extra costs! For both sus' seat and forks! Seat first though!
DK35vince
You didn't make me mad.
We just have a difference of opinion.
You believe suspension seat and flex forks are a waste of money. That's fine.
I believe my suspension seat and flex forks was money well spent. They do make a difference.
Carscw
You didn't make me mad. We just have a difference of opinion. You believe suspension seat and flex forks are a waste of money. That's fine. I believe my suspension seat and flex forks was money well spent. They do make a difference.
Maybe some day I will try them.
MPW1216
+1 on the flex forks. Made a noticable difference in ride and well worth the cost. As for scalping, negligable versus fixed forks. Personally think flex forks should be standard issue. :thumbsup:
MPW
Nickwilkins
I recently bought the fastrak SD 54", later added the flex forks and just added a suspension kit for the seat from eBay for $125 shipped. In my opinion, they were both well worth the money. I have yet to scalp anything. I mow some areas that are VERY rough and it has been a night and day difference. Now that the ride is smoother I can mow about 30% quicker in the tough areas and haven't noticed a change in the cut quality. However I have only mowed twice since the seat kit was added.
specman
Who wants to feel like they went 10 rounds with Mike Tyson after a weekend of grass cutting. Not me. If it's comfortable and you are satisfied with the job it produces, go for it.
