New Member
patme
I'm new to the site and just wanted to say Hi. My name is Jimmy, I have a Craftsman 42inch, with a 23hp V2 Briggs engine. One thing I like about this mower is you don't have to stop to shift gears, just mover the lever back and forth to change moving speed.
I do have a question, when I disengage the blades they do not disengage. I have to shut off the engine to make them stop. Any suggestions?
Check to see if wire harness plug has come loose at pto clutch bottom of engine. Also post your tractor model number and all numbers from engine:
model xxxxxx, type xxxx, trim xx.
Welcome to the forum.
Hello Jimmy! Welcome to LawnWorld.
:welcome:
I suggest asking your question in the Craftsman forum to receive answers from other members. Good luck!
This lawn mower does not have the electric clutch on the engine shaft, (I wish it did) blades are engaged with a lever on the dash next to the steering wheel.
It is a Craftsman LT 2000,
Model #: 917. 275520
Serial #: 033005C005305
Engin #'s on Valve cover
Model #: 445577
Type: 0485 E 1
Code 050324 G
Briggs & Stratton
INTEL TWIN 23 OHV
Model #: 445577
Type: 0485 E 1
Code 050324 G
Briggs & Stratton
INTEL TWIN 23 OHV
Try to adjust clutch cable and see if blades won't disengage. Inspect everything from blade engagement lever downward. Also inspect clutch cable assembly and see if it's stretched or worn out. Information: http://www.searspartsdirect.com/par...AN&modelDesc=TRACTOR&blt=11&shdMod=&keyId=152
http://www.searspartsdirect.com/par...7/1509200/P0501045/00010?blt=06&prst=&shdMod= Item 152 parts diagram
Model #: 445577
Type: 0485 E 1
Code 050324 G
Briggs & Stratton
INTEL TWIN 23 OHV
Object moved
