twall
- Feb 27, 2011
- 1,628
So, you look at an ad for a mower.
Looks okay for the weedeater one. Its a tiny little RER. 9 should be enuff.
HP? The Hp rating is 6.5 horse. Now that's a number I'm familiar with, and that's pathetic. I've used 8hp RER's, and that was barely sufficient, if you have a rainy month.
Why do they do that? It's said, 'torque is more what you'll need, so its a better gauge'. Really? I know what a 6.5 horse is like. But, I really have nothing to gauge torque by, because for the last 50 years or so, they've used Hp ratings!! Did they do anything to 'up' the torque? No. Then why use it? To confuse you. That way, they can use a cheaper engine with a different rating, and you think it's either okay, or just a tad anemic for a 9hp. But it isn't 8.75 HORSE, it's TORQUE. A 9horse would probably net you 14 ft/lbs. Then you'd think it's a 14hp. See?
'Seat of the pants' is a bad dyno.
What do you think?
- 190cc
- 8.75 ft/lbs torque
- Hp - none listed
What do you think?
