basstracker
- Jul 9, 2013
- 51
I left the oil stick out and started the engine, it blew oil out where you put it in. should it do that or is something wrong with the engine?
Check the oil level in the engine to see if its in the safe zone on the dipstick, if oil is ok then you should be good to go. It is normal for oil to come out of the dipstick hole if the dipstick is not in place and the engine running.
