TECHUMSEH 10hp PARTIOT pro series chipper/shredder
emeraldgirl
gas leaking from the screw in bowl below the carburetor.
the screw looks like a bolt. it has no adjusting spring, there is a small white tube inside the bolt, that has a hole in one end and one side. tried adding washer that did not work. it did not leak last yr. can anyone help me??
It should have a fiber gasket that goes with it. You may have to buy a needle valve kit to get the gasket. I haven't seen them sold alone, but I could be wrong.
L8R,
Matt
L8R,
Matt
ty
i will try to find the kit
could i cut a gasket out of the cork like gasket material
All you need is the engine # from the shroud and you'll be good to go. While you have the main jet out, that bolt, make sure the tiny openings are clear. A piece of solid copper wire or even a piece of guitar string will be all you need to run through the holes...
L8R,
Matt
